CVE ID: CVE-2026-54588
Published: June 23, 2026
Description: Poweradmin is a web-based DNS administration tool for PowerDNS server. Versions prior to 4.2.4 and 4.3.3 use the attacker-controlled `HTTP_HOST` request header as the authoritative source for building callback URLs in its OIDC, SAML, and logout authentication flows without any validation. An unauthenticated attacker can poison the `redirect_uri` sent to the Identity Provider, causing the IdP to redirect the victim's authorization code to an attacker-controlled server - resulting in full account takeover with no credentials required. Versions 4.2.4 and 4.3.3 patch the issue.
Severity: 9.6
https://cvefeed.io/vuln/detail/CVE-2026-54588
CVE-2026-54588 - Poweradmin has Host Header Injection in OIDC redirect_uri, SAML ACS/SLO URL, and Logout Redirect Constr
