CVE-2026-60005 - NGINX ngx_http_slice_module vulnerability
CVE ID: CVE-2026-60005
Published: July 15, 2026
Description: NGINX Plus and NGINX Open Source have a vulnerability in the ngx_http_slice_module module. When the slice directive and unnamed regex captures are configured or when a background cache update happens, unauthenticated attackers can send requests that may cause uninitialized memory access in the NGINX worker process, leading to limited disclosure of memory or a restart. Impact: This vulnerability may allow remote, unauthenticated attackers to have limited control to disclose memory contents or restart the NGINX worker process. There is no control plane exposure; this is a data plane issue only. Note: The ngx_http_slice_module module is not enabled by default; it's enabled with the --with-http_slice_module configuration parameter. Note: Software versions which have reached End of Technical Support (EoTS) are not evaluated.
https://cvefeed.io/vuln/detail/CVE-2026-60005
